Is there a way to find the actual RBW used in E5052B Phase noise measurement mode. Manual specifies that RBW is "AUTO" set in phase noise measurement mode.
FYI I am dealing with 156.25MHz carrier frequency with its phase noise curve viewed in 10kHz - 40MHz bandwidth.
I need this RBW info to convert some of my spot phase noise raw data values in dBc/Hz to dBc.
Mahesh
Mahesh
There is an excellent online help page for this product here:
[http://ena.support.keysight.com/e5052b/manuals/webhelp/eng/?nid=-35185.631410.00&cc=GB&lc=eng]
Type 'bandwidth' in the search field and you should see the relevant programming commands.
I think the command you need is therefore:
:SENSE:PN1:ROSC:BAND?
I hope this helps.
Regards, Simon C.
