currently i am searching for an easy way to trigger a quick print via with the MSO6104A.
My goal is to have a print of the current signaling on an usb stick after a new triggered signal. Is there a easy possibility without writing a complex application in C...
Thanks for help,
justin1990
Thanks for help,
justin1990
see attached. It's pretty much all there. Even if you are not python friendly (you could be; there is a getting started guide included), the python scripts are just text files, and they are well documented and easy to read. So... you can easily put this together from here.
