Hello All,
How do I get Command Expert Object to show the sequence of commands in the object window.
I can see the sequence if I right click the object, but is there a way to always show the
commands if the object is opened inside VEE without having to double click and launch command expert, or right clicking and seeing the command sequences in a window.
I want them to be viewable in the object, just like a normal user object.
thanks
Using VEE 9.32 / Windows 7 Pro.
thanks
