SCPI command to send transmit enable trigger to signal generator 4438C
Question asked by vincent001 on Jan 19, 2016
Latest reply on Jan 20, 2016 by vincent001
I am using this example to send a simple waveform to the signal generator. the example worked but it did not send the trigger pulse at the start of the waveform. what would be the SCPI command to make the trigger appear at the output connector in the back of the equipment?
thanks.
https://www.mathworks.com/matlabcentral/fileexchange/24048-generating-waveforms-on-agilent-mxg--esg--psg-signal-sources-using-matlab/content/Generate_Waveform_Agilent.m
