Hello everybody,
I am new in this forum and I hope I could learn from you with your help.
Well, I have got a signal generator HP8648C with serial number 3642U1637 but I have a problem with this equipment.
Any of you can me advise what to do for going out from the PULSE mode, please?. I have read in the manual that it is necessary to apply a TTL- high signal to the rear-panel PULSE IN connector.
The problem is that this version has not that connector .
I tried from different ways but without sucsses.
I hope you can help me to find a solution. I will be realy grateful to you.
Thank you in advance for your help.
Best regards
Rafael Suarez
oa4dma
Best regards
Rafael Suarez
oa4dma
Thank you very much for your answer xmo.
Then, if the equipment does not has Pulse option, this means that it has another problem?, isn´t it?
Every time I pulse button "RF on/off" appears RF OFF and then PULSE.
So, Is there a procedure to go out from this and get RF ON?
Something else, the PULSE option appeared when I changed the battery 2/3A but before that I was
pressing buttons of the generator to recognize it, the RF ON mode was working.
THanks in advance for your help.
Best regards
rafik
oa4dma
I hope this helps.
Greetings
rafik
