I have written the following code using scpi and pyvisa for automating the temperature of 2 wire thermister connected with DMM 34470A.
import visa
import numpy as np
rm =visa.open.ResourceManager('@py')
digital_multimeter = rm.open_resource("TCPIP0:186:129:300:243::inst0::INSTR")
digital_multimeter.timeout= 5000
number_of_readings =1
digital_multimeter.wrote("*cls")
digital_multimeter.write("*IDN")
print digital_multimeter.read()
#configuring instrument
digital_multimeter.write("CONF:TEMP THER")
digital_multimeter.write("TEMP:TRAN:THER:TYPE 5000")
digital_multimeter.write("TEMP:TRAN:THER:POW:LTM ON")
digital_multimeter.write("SAMP:COUN %d" %number_of_readings)
print "readingtemp of thermister"
digital_multimeter.close()
print "complete"
after printing the IDN of device, it is only printing : reading temp of thermister" but it is not printing the temperature showing into the device.
I am new to this programming. Please help me to correct my code and get the desired output.
import visa
import numpy as np
print "complete"
Then you just forgot a couple of commands.
To get the DMM started you need to send INIT, this will tell it to start taking measurements. Then send FETCH? followed by your digital_multimeter.read() to read back the data
If you want you can send READ? in place of the INIT, FETCH? combination
