trying to load a waveform into a 81150A, either through LAN or USB file or any other proven method, planning to use vba if programming is needed.
is it possible to read in/load a .txt/.dat/.mat/.csv file?
is it possible to load a file via vba? could not find any manuals or commands to perform this task
many thanks
many thanks
HELLO I WORK WITH THE GENERATOR KEYSIGHT 81150A I have to generate a waveform to excite a sensor with labview I don't know how to do .
thank you
