Is there a way to print recent loaded testplan name
I need to determine the filename of the testplan during execution
If I load the abc_testplan,I want to print file names (abc_testplan)
print "You are using testplan_X"
If you use different testplan for one product is more work for you. You need integrate all your variants in just one testplan. This will make your life more easy in the future :)
Saludos...
RM
