ENA E5061B 75 ohms version - how to set Unknown Thru?
Question asked by mirek on Apr 21, 2015
I do not see in ENA E5061B 75 ohms version Unknown Thru in cal kit definition. In ENA 5071C you can defined Unknown Thru and put the adapter delay manually or use VBA macro to do that. The VBA macro for 5071C do not work in E5061B (probably because the Unknown Thru is not in there).
What you need to do to eliminate the thru adapter loss from calibration?
Regards.
