I have installed the latest version (5.90) of the Logic Analyzer Software on a 16903A. When I open the COM Connection Tool and try to connect to either 'localhost' or the actual IP address of the LA, i get the error message:
'Unhandled exception has occured in your application. [...] Could not load file or assembly 'Interop.AgtLA, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified'.
I have also installed the LA Software 5.90 on a Windows 7 PC, and i get the same error message.
Otherwise the LA works fine, and it's probably not a networking issue. E.g., from the Windows PC i can connect to the 16903A.
Anybody else having the above COM problem with the LA Software 5.90?
My personal recommendation would be:
- Remove all of the LA SW, from both the LA, and the PC, removing the Demo Center, the License Server, and then the main app.
- Make sure that everything that looks related to the LA SW, except any license files, have been removed from the Agilent Technologies and/or Keysight Technologies directories.
- Run a registry tool, like CCleaner, just to be sure
- Reinstall the LA application and try again.
Al
Disclaimer: For more reliable response, you should consider calling your local Keysight Technical Call Center. The Keysight Forums are monitored on an "as available" basis, and aren't necessarily the fastest way to get technical questions answered.
