Hi, I used an example program for C# for GPIB interfacing. It was working fine with my equipment for more than a month but after today the program throws a COMException error with no code. The example program is:
namespace ExampleProgram
class Program
public static int Main()
ResourceManager rMgr = new ResourceManagerClass();
FormattedIO488 src = new FormattedIO488Class();
string srcAddress = "GPIB0::30";
*src.IO = (IMessage)rMgr.Open(srcAddress, AccessMode.NO_LOCK, 2000, null);*
src.IO.Timeout = 2000;
src.WriteString("*IDN?", true);
string temp = src.ReadString();
System.Console.WriteLine(temp);
return 0;
The error is thrown where the bold line is. Basically, it means I cannot connect to my instruments from C#.
I am using the Visa COM library type 5.5 and netframework 4.6.
I really have no idea what could be wrong since Friday night (20-11) it was working fine but this morning (23-11) it did not work anymore and I did not change a single line of code. I noticed there was an IO library suite update on 21-11 but I do not know if this could be a factor.
I tried reinstalling my NI 488.2 drivers (i use a NI GPIB usb plug) and the IO library suite drivers but no good results.
Keysight Connection Expert still works properly. I can send GPIB commands to my instrument such as *IDN and I can read the correct response.
Any insight would be appreciated, thanks.
class Program
return 0;
When you say "reinstalled IO Libraries", do you mean re-install with an older version to verify that the new version is giving problems?
What instrument are you connection to, by the way?
