We have 89601B 14.23 ver software with MXA.
I attempt to use Input-->Extensions SCPI commands, for example, ADC Dither.
however, it does not work.
For example, I try to ask VSA return its Adc Dither value, my SCPI command is as below
:INPut:EXTension:PARameters:GET? "ADC DITHER"
It is not working.
When I use 89601B with Scope (Infiniium), the SCPI command works well,
For example,
:INPut:EXTension:PARameters:GET? "SampleMode"
It would return the value 1,2 or 3. it works well.
May someone have same problems?
many thanks.
It is not working.
For example,
many thanks.
<- ADCDither,ADCDitherBaseband,IFType,ExtTriggerLoc,CaptureBitPacking,uWPathControl,PhaseNoiseOptDualLoop,ExtRefLockBW,InstrUserCorrections
-> :INPut:EXTension:PARameters:GET? "ADCDither"
<- 0
