Testjet, polarity check failures after change to ASRU N and Control XTPA
Question asked by BillT on Nov 2, 2015
We upgraded our Series II/III to a Series III/V recently.  Replaced ASRU C revision with ASRU N Revision USB and Control XT cards to Control XTPA.
Now we are seeing not only low value capacitor and resistor tests that we knew would require debugging, but polarity check tests that no longer work at all.  One test IPG did generate with tests commented due to low impedance but the items were uncommented and worked under the old hardware.  Now none of them work at all.
Anybody else see this?
Telling our customer that due to an upgrade the test no longer works is not going to be an option.
