I want to transfer a trace data from Agilent EXA N9010A Signal Analyzer to PC. To do that, I use C# and
visa32.dll. The description of what i do and the problem is as follows:
1. I connect and open a session to the instrument using SOCKET, where resourceAddress is
TCPIP0::192.168.183.10::5025::SOCKET
visa32.viOpen(resourceManager, resourceAddress, visa32.VI_NO_LOCK, 25000, out viSession);
visa32.viSetAttribute(viSession, visa32.VI_ATTR_TMO_VALUE, 25000);
visa32.viSetAttribute(viSession, visa32.VI_ATTR_RD_BUF_OPER_MODE, visa32.VI_FLUSH_DISABLE);
visa32.viSetAttribute(viSession, visa32.VI_ATTR_TERMCHAR, 0x0A);
visa32.viSetAttribute(viSession, visa32.VI_ATTR_TERMCHAR_EN, visa32.VI_TRUE);
2.I set the number of points to 601, set the analyzer into single sweep mode, set the trace data format to "REAL,32", set the trace data byte order to NORM and take one complete sweep.
Now I have two different problem;
3.When I try to read the data(using %#zb format) after sending ":TRACe:DATA? TRACE1" command, the size of the data I get is less than the Instrument buffer(I analyze the TCPIP bus using WireShark). In the Instrument buffer, there is correct number of bytes but I get less data(sometimes 32-bytes, sometimes 300bytes and it changes)
4.When I do above steps more than one, I got format error from visa session
Is there any solution for this.
Regards
Regards
