I am in the process of updating our test benches to new DAQ, GPIB, and VEE 9.32. I have everything installed, but VEE throws errors when trying to communicate to any instrument on the GPIB. When I try to create a panel it gives a timeout error. Nothing shows up on the IO Monitor. The Connection Expert is able to communicate with the equipment.
I have tried uninstall and reinstalling VEE and the same problem occurs. I have tried direct IO and still nothing.
Any ideas?
Any ideas?
To get your older programs to work you might have to check the "Enable Pre 8.0 Legacy I/O" box under File > Default Preferences.
-Bill
