Hi there,
I've just installed the IO Suite 17.2 and I've discovered that the Connection Expert seems to forget/reset the settings I'm putting it.
On the Manual Configuration tab, I choose Edit Existing Instruments/Interfaces and then the GPIB Interface (I'm running the connection through a 82357B) and click Accept.
Connection Expert applies the setting but some time later just goes ahead and turns it back on.
This is annoying because I have an older piece of HP gear that doesn't understand the IDN? command and so it's always showing a command error.
How do I get this to stay permanently off?
TonyG
TonyG
Whenever you unplug the 82357B, I/O libs erases all knowledge of it ever existing, so any settings you entered will be put back to the defaults.
If you could describe the desired behavior for you, I can feed that back to the design team and hopefully get some changes made in future releases.
