We recently upgraded all of our programs from Vee5 to Vee9. In every instance, programs that executed flawlessly in V5 now would crash in V9 where we had instances of "EXECUTE CLEAR".
We had to remove each instance and replace those commands with "IP" or "*RST" or any other unique instrument preset state. As I am not looking forward to going through each line of code to dump this out, I wanted to see if others have also had these problems and what their workaround was.
BTW - we have already set the program preferences from V5 to V9 and that had no effect.
Thanks, Mike
Thanks, Mike
I have never experienced this, but that could be because I've always upgraded to each new VEE version at the time they were released. I do remember having some issues when VEE changed the way I/O was done in Version 8.0, but those were usually solved by checking "Enable Pre 8.0 Legacy I/O" under Default Preferences > IO. Did you try that?
-Bill
P.S. You'll get faster answers to your questions if you subscribe to the VEE reflector as described below. It's a low traffic mailing list so don't worry about getting flooded with email.
VEE Reflector:
To subscribe please send an email to: "vrf-request@general.lists.agilent.com" with the word subscribe in the message body (no long signatures and plain text only).
To unsubscribe send a blank email to "leave-vrf@general.lists.agilent.com" (no long signatures and plain text only).
To send messages to this mailing list, email "vrf@general.lists.agilent.com".
If you need help with the mailing list send a message to "owner-vrf@general.lists.agilent.com".
