I try to cummincate with an Agilent e4438c with labwindows using SCPI language through an ethernet cable. I configured my system and it communicate well with other utilities like MAX.
But, when i try to run my labwindows program, with SICL language, it doesn't work, it seems to communicate but not to follow the other instruction.
my little test program :
char* instOpenString ="lan[My IP Adress); (like that for no link)
INST id=iopen(instOpenString);
if (!id)
fprintf(stderr, "iopen failed (%s)\n", instOpenString);
return -1;
iwrite (id , "*IDN?\n" , 6 , NULL , NULL );
itimeout(id, 2000);
iread ( id , buf , 200 , NULL , &actual );
iclose(id);
I have no return reponse like "iopen failed" so I think the connection works well, but buf and actual never change, it's like if it didn't read anything from the e4438c.
*I solve this problem and now find an other. When I try to download IQ Data to the Agilent, loading stay at 0% and never progress. So it receives well my command but not the data i think. I try like this :*
sprintf(cmd, ":MEM:DATA \"WFM1:FILE1\", #%d%d", strlen(s), bytesToSend);
iwrite(id, cmd, strlen(cmd), 0, 0);
iwrite(id, iqbuffer, bytesToSend, 0, 0);
iwrite(id, "\n", 1, 1, 0);
Cause i didn't see how use the command :
:MEM:DATA <"file_name">,#ABC with C the file data in bytes. ( Must be ASCII characters ?)
THANKS for your help.
if (!id)
return -1;
itimeout(id, 2000);
iclose(id);
