PNA 5230C saving citifiles
Question asked by sydmil on Feb 20, 2009
Latest reply on Feb 22, 2009 by sydmil
I was wondering if anyone might be able to help me with the following problem I have saving the citifiles.
The problem I have is that sometimes the citifile data is not saved correctly. In the saved file I get a column of magnitudes and angles, but the angle value is only either 0 or 180.
However, using the same data saves format I sometimes get the correct data format (see example below).
The data saves format as follows:
Citifile Content: Auto
Citifile Format: Log Mag/Angle dB/deg
I save using “save as citifile formatted data”.
Would anyone have any suggestion as to what might be going on ?
Thanks you!
correct data     /                    incorrect data
BEGIN                                         BEGIN
-22.375723     -0.77644426     /                     -40.302109     180
-26.52953                    -46.554649          /          -35.019447     180
-21.416016     -17.6157          /          -35.238804     180
-32.015163     15.204881          /          -36.470661     180
-35.712494     104.01944          /          -43.025196     180
-17.932049     14.616544          /          -39.662544     180
-23.181046     -90.143188     /          -40.293358     180
-23.535969     126.34192          /          -44.68631                     180
-16.791178     37.695843          /          -42.717243     180
-18.008064     -52.302517     /          -43.992527     180
-22.627804     146.96127          /          -43.636822     180
-16.779001     63.341633          /          -47.429737     180
-16.012423     -14.523798     /          -44.876465     180
-25.086855     -124.58897     /          -50.043587     180
-20.537281     89.301186          /          -45.908535     180
-16.067846     9.7169418          /          -40.444958     0
-20.038504     -50.0755          /          -27.752563     0
-27.264408     131.17134          /          -20.757063     0
-17.470449     39.358009          /          -18.014914     0
-17.302494     -12.21299          /          -19.462948     0
-25.373011     -62.713875     /          -18.037891     0
-20.816889     67.224655          /          -18.655325     0
-16.34952                     13.087127          /          -22.473152     0
-19.860783     -28.486507     /          -24.271242     0
-27.564976     29.252195          /          -21.689219     0
-17.434958     20.075663          /          -21.421099     0
-16.957155     -18.386019     /          -22.109844     0
-22.060286     -21.876715     /          -22.480436     0
-25.375582     -4.5607319     /          -22.643274     0
