I am relatively new to the ADS. I am trying to build the schematic of my circuit in ADS, it involves multiple ICs from different vendors. I have imported component library from the vendor into ADS. However some ICs are not available in the library. How should I resolve this issue? Is there any way I can model the entire IC in ADS.
I have performed S parameter simulation using data items and S parameters file from the vendor. Now I just need to build the system schematic which shows all the pin connections of the IC. Its fine with me if this schematic cant be simulated.
Please help!
Wasim
Edited by: wassoshaikh on Apr 14, 2015 2:21 PM
Please help!
Wasim
