I have a Keithley 2182 A nanovoltmeter and a DC power supply. I need to take two measurements form the same circuit ; one across a shunt resistor and one across another resistor in series. I need to know the following:
1. I will continuously vary the supply DC current to the system and need to take multiple readings form two channels simultaneously and store those values in a computer.
2. Is it possible to measure voltage across two resistors in a circuit and store these values in the computer until I switch off the power supply?
Thanks a lot! Need urgent assistance on this... Thanks again.
