Can someone tell me how the CSV file should look like for the U2761A USB generator?
I need to create a arbitrary wave form (values calculated in excel), so the "drawing" app is not good enough. I need to set exact timings en levels. No info in teh help whatsoever.
I had a look at some files and in the header i see
Data,Name,Freq(kHz),Ampl (Vpp),Offset (VDC),Points
what is meant with those parameters? DO i need to set it for each sample?
how to i send this wave file only once? I also see the freq setting in teh AMM is important...
