I have a question regarding my application. I think I already know the answer but it doesn't hurt to ask.
The following information is what I am wanting to do:
I would like to continuously capture values from 3 signals below.
1. Analog pulse
2. Analog signal
3. CAN data with dbc.files
I would probably do an edge trigger on the analog pulse as the other two signal is a somewhat a calculated value of the pulse.
I would need measurement of the following:
1. minimum of signal 1
2. fall time of signal 1
3. y-cursor value of signal 2
4. specific CAN message
The pattern are repetitive and they can go up to max freq of 25Hz.
So the idea is not to do single trigger and capture the measurements.
I would like continuous measurement of every single events.
Currently I do programming using MATLAB (not vB or C# proficient :p).
I know ideally people would use DAQ devices probably from NI to do this kind of stuff but was wondering if I can do it with oscope.
1. Analog pulse
2. Analog signal
There are other tools, such as digitizers, that can provide continuous data capture, but they don't usually have any built-in measurement or decode capability.
Al
