Hy,
I use Labview to remotely control a Keysight 33522B which is also sometimes used manually by my co-workers. But whereas they use the "Amplitude/Offset" setting to set the voltage I use the "High/Low" setting.
So my question is if theres a SCPI-Command to set the Device to High/Low without needing to change it manually at the fron panel.
Bell
Edited by: Bell on Aug 21, 2015 4:15 AM
Bell
