from time to time I get 16902B (Win7) frame start-up Errors, as on pics attached:
- Bad JTAG init error code: 1
- Unknown frame type (not M1, M2, M3, or M6): 255
(either one of them could appear, and for sure not both of them at same time)
Any ideas, what could it be and what to check ?
(probably, but not sure, that happened for the first time after the frame transportation from one office to another)
Thanks!
Thanks!
If this happened while moving the frame, it's probably a loose connection somewhere. In any case, I would pop the covers, with the power off and disconnected, and wiggle cables. Make sure they're all well-seated.
Al
