PNA-X calibrated wideband pulse measurements
Question asked by MrBaker on Aug 16, 2009
Latest reply on Aug 20, 2009 by Dr_joel
we want to do pulsed S-aparameter measurements using the PNA-X with 2-port calibration turned on. For this we use the "Wide-Band Pulse Mode Application for PNA-X" to set the PNA in pulsed mode with external triggering of the pulse modualtion.
Our problem is that after entering the Pulse Macro, for starting pulsed mode and to set the RF-modulation pulse to external trig, the correction is turned off. Even if we have performed a calibration under the same conditions (pulsed mode same IFBW etc.) the corretion is turned off (the PNA-X dispays a message saing that stimuli settings are changed )
Any suggestions ?
