Hello everyone,
I'm trying to simulate a HF rectifier circuit but from the results the diodes are not simulated correctly (i.e. as diodes) and as the circuit is a voltage quadruple rectifier the output should be more than 63mVpp which is simulated on the input. I feel that the diode rectifying function is not correctly simulated. Please advise
PS: I also ran a power test for an input power of -20dBm ( as for amplifiers) and i get a o/p power of -19dBm-makes no sense
Thank You Ed
Thank You Ed
