I could not find any documents for N2815A cable, so my question is which
of the cables (U4201A or N2815A) is correct to order for use with U4164A and
DDR3 probes (cable E5845A) or DDR2 probes (cable E5384A/E5826A) ?
One U4164A module set-up. Command/Address/Data bus decoder.
Which quantity of cables should be considered for order ?
5992-1057EN U4164A document mention that N2815A cable is
"MSO/logic analyzer cable for connecting U4164A to 90-pin logic analyzer probes.
(Connects even and/or odd headers of E53xx and E54xx Series 90-pin probes into
odd pod of U4164A pod pair only. Useful for dual-sample state mode, not for
full-channel mode).
Thank you very much!
full-channel mode).
for this product nor any specific N2815A-related datasheet...
Not clear, is it real Keysight product helpful for DDR3 dual-sample mode with bus-decoder sw use,
already available for the order (also no prices mention anywhere) ?
I'm planning my future order of U4164A, having in mind DDR3/DDR2-designs debug with Keysight bus-decoder sw,
(E5845A, E5384A/E5826A cables) and I could not identify correct product and quantity for the order (U4201A or N2815A).
DDR3-1867 x16 (16bit or 32 bit bus configuration), DDR2-800 x16 (32 bit bus configuration).
PS. Now I have used 2x16962A hw set-up, thinking of upgrade to higher memory speeds and possible future
support of DDR4 memories... also is it enough just one U4164A for 16/32 bit bus width configs ?
