I am very curious about the following:
Background: I do 16-Port sweeps ending with several .s16p files. However, much of that data is never used.
Is it possible to do the following with a PNA-X (I'm using the N5225A)?:
1) Do a 16-Port Calibration
2) Tell the VNA to do an arbitrary number of 4-Port Sweeps.
3) Use the errors terms from the 16-Port Calibration to correct the 4-Port Sweeps I have told the VNA to collect.
This is done through the use of GPIB.
If this is possible, could you please guide me into executing this with my setup? This is crucial.
-KTB
PS - Just want to say you guys have done an extremely excellent job at providing quality responses to problems. If there is something meaningful that I can do in terms of reviews/surveys/whatever for you, please let me know as I would love to give your support an A+++ rating.
-KTB
the link below will show you the command that you need to apply to each trace in your channel.
[http://na.support.keysight.com/pna/help/latest/Programming/GP-IB_Command_Finder/Calculate/Correction.htm#ErorType]
