Please see the picture as the attachment.
The size of pin and its text is too big, and I can't find anywhere to adjust the size...
I've tried options→preference→Pin/Tee→ size, but it seems useless...
Please tell me how to do?
Thanks~~
Thanks~~
You can also use the menu command Edit > Component > Pin/Ground Size to open a simpler UI to make this same change.
The Component/Pin Text tab in the preference editor will change the text size for pin annotation and any new components you place in the layout. To change the text size of a component trhat is already placed in the layout you need to select the component and use the menu command Edit > Properties... to open the Properties panel and change the Component Text Size.
