I have an oscilloscope model DSOX3012A. It receives signals from two pressure transducers mounted in my flow system. I'm trying to save these signals (Voltage) in an excel file. I mean I want a file whose first column is time (real time starts from zero) and the second column is the correspondent voltage.
I did that by capturing the waveform, but it only saves the data for one cycle and also it starts from -T/2 to +T/2.
If you have any way to do that by LABVEIW, Command Expert or any other program, please let me know.
