I have an SMT microstrip fixture which uses TRL inserts from intercontinental microwave. I have a 3.5" disk with coefficients but cant figure out how to upload cal constants into 8753ES. So I referred to manual on TRL error correction to manually insert coeff. Using short reflection, zero distance thru, and Line 1, I entered user defined parameters. Modify standards, assign standard class, label class, label kit, save user kit. 3x. I realize I must be doing something wrong. Can anyone give me some ideas or tell me how to upload from 3.5# disk.
Try this
* Power on, or press "Preset" if already on
* Insert floppy
* Press the "Save/Recall" key
* Press the softkey for "Select disk"
* Press the softkey "Internal disk"
At this point, assuming your floppy drive still works, you should get a list of the files on the floppy.
* Press the softkey "Return"
* Use the knob to select a file
* Press the softkey "Recall state"
that will then load the coefficients into the USER kit.
It is very easy to go wrong with defining the coefficients manually. The menu structure is pretty poorly thought out. I once see a comment that bit was either written by a disgruntled employee or an intern! There are some notes on my website about some of the issues.
Personally if I were going to modify a TRL cal kit, then I'd start with one that is similar. The most similar kit I can see in the 8753ES firmware (mine has the latest 7.74) is the 85052C 3.5 mm kit.
Note, that the 8753, being a 3-receiver VNA, can't do a true TRL cal - only TRL*. It is best to stick a high quality 6-10 dB attenuator at each cable, so there is a good match. You should be able to find information about that in the 8753ES manual and/or some Agilent application notes.
Hopefully I have!
Dave
Edited by: drkirkby on Oct 9, 2015 9:03 AM
