There could be some background to this as i uninstalled the SW and relocate it to a different drive. Since then i get the following error when trying to open the local help file with F1:
The page could not be found qthelp://ads.2015.01/doc/support/Home.html or error 404.
I uninstalled again and reloaded to the original location but still the same.
Could there be a remnant registry record that is not updated during reinstall pointing to the wrong location?
Thank You
Ed
PS: the support folder is missing yet I'm sure i selected the help option active (twice actually) and also re-downloaded the package using AKAMAI in case the archive is damaged in any way.
Thank You
Ed
Ed,
I am not sure if you have resolved this issue yet, but if you haven't and for the benefit of others, one thing to check is to open the ADS 2015.01 Help window, then go to the Edit menu on top and select "Preferences..."
In the Documentation tab there should be 2 items listed:
ads.2015.01
ads.2015.01.img
If these are missing, select the "Add..." button to the right, and browse to you \doc\ and add the two files:
ads.qch
image.qch
The Help application should now build the index of help files, and you should be good to go.
Gunnar
EEsof Support
Edited by: GUNNARB on Aug 27, 2015 7:44 AM
Edited by: GUNNARB on Aug 27, 2015 7:47 AM
