I'd like to read the EVM results of an LTE signal on the PXA N9030A using the SCPI commands. For some reason the commands to get the EVM results are not available using Keysight Command Expert (See list and pictures below).
:CONFigure:EVM
:FETCh:EVM[n]?
:INITiate:EVM
:MEASure:EVM[n]?
:READ:EVM[n]?
:CALCulate:EVM:DATA:TABLe:STRing?
:CALCulate:EVM:DATA:TABLe:NAMes?
:CALCulate:EVM:DATA:TABLe:UNIT?
:CALC:EVM:DATA4:TABL:STR? “FreqErr”
I can also see that X-Series Signal Analyzers LTE FDD Commands versions A.06.06 and A.08.03 are installed.
Is there anyone having similar issue and know to fix this?
Thank you,
Pierre
:CONFigure:EVM
:FETCh:EVM[n]?
:INITiate:EVM
:MEASure:EVM[n]?
:READ:EVM[n]?
:CALCulate:EVM:DATA
:CALCulate:EVM:DATA
:CALCulate:EVM:DATA
Thank you,
Pierre
EVM and CEVM is now visible in CONFIG:: and MEAS::
