A couple of questions about the probe integration.
1)- What is the meaning of option "B4655A-0D4 Delete Installation" listed in the product page?
2)- Under Compatibility the following devices are listed:
Xilinx FPGA devices: Virtex-5, Virtex-4, Virtex-II Pro, Virtex-II, and Spartan-3
Is the probe exclusively compatible with these devices or does support exist for the Kintex-7 family of FPGA?
-- If a SW product is on the same order as a Logic Analyzer, then it is, by default, installed and licensed on that analyzer. If the buyer/user wants to install the SW on, and add the license to, a different LA, or maybe a PC, then the 0D4 option is ordered.
2)- Under Compatibility the following devices are listed: Xilinx FPGA devices: Virtex-5, Virtex-4, Virtex-II Pro, Virtex-II, and Spartan-3
-- The B4655A DOES support the Kintex-7 series of Xilinx chips, but we do not yet officially support Vivado designs.
Al
Disclaimer: For more reliable response, you should consider calling your local Keysight Technical Call Center. The Keysight Forums are monitored on an "as available" basis, and aren't necessarily the fastest way to get technical questions answered.
