Hi:
This is in continuation of my previously asked question. So, I simulated the voltage level of a active device and imported the voltage waveform in EMpro. I assigned that voltage waveform at a port (as feed) at an approximate location where the active device is located in the physical layout.
Question 1:
In the feed definition, I select the feed as voltage type and select the corresponding voltage waveform (imported). What should I give as the Amplitude? Will it be the highest value from the imported voltage waveform?
AD
Question 1:
AD
If the data imported is normalized one, then you should enter appropriate scale factor for the amplitude.
Hope this helps.
