I am programming in LabVIEW but using the VISA-COM example as a guide.
The following is the programming example in the PDF file.
Can someone explain to me why the step is obtained by dividing the number of data bytes by 20?
Earlier :WAVEFORM:POINTS 1000 was sent
Line:-----
' QUERY_WAVE_DATA - Outputs waveform data that is stored in a buffer.
' Query the oscilloscope for the waveform data.
myScope.WriteString ":WAV:DATA?"
' READ_WAVE_DATA - The wave data consists of two parts: the header,
' and the actual waveform data followed by a new line (NL) character.
' The query data has the following format:
' Where:
' = #800001000 (This is an example header)
' The "#8" may be stripped off of the header and the remaining
' numbers are the size, in bytes, of the waveform data block. The
' size can vary depending on the number of points acquired for the
' waveform. You can then read that number of bytes from the
' oscilloscope and the terminating NL character.
Dim lngI As Long
Dim lngDataValue As Long
varQueryResult = myScope.ReadIEEEBlock(BinaryType_UI1)
' Unsigned integer bytes.
For lngI = 0 To UBound(varQueryResult) Step (UBound(varQueryResult) / 20) ' 20 points.
If intBytesPerData = 2 Then
lngDataValue = varQueryResult(lngI) * 256 + varQueryResult(lngI + 1) ' 16-bit value.
Else
lngDataValue = varQueryResult(lngI) ' 8-bit value.
End If
strOutput = strOutput + "Data point " + _
CStr(lngI / intBytesPerData) + ", " + _
FormatNumber((lngDataValue - lngYReference) _
* sngYIncrement + sngYOrigin) + " V, " + _
FormatNumber(((lngI / intBytesPerData - lngXReference) _
* sngXIncrement + dblXOrigin) * 1000000) + " us" + vbCrLf
Next lngI
MsgBox "Waveform data:" + vbCrLf + strOutput
Line:-----
' Where:
Dim lngI As Long
Else
End If
Next lngI
