I am using an oscilloscope "AGILENT TECHNOLOGIES,DSO-X 2002A,MY53280682,02.35.2013061800'.Then I connected the oscilloscope with my pc with usb and I must mention that I'm using VISA driver for connection purpose that I got from your company's network.Then I have tried to capture data from the oscilloscope with instrument control toolbox in matlab(2013).All the preliminary steps were well executed.But when I attempted to execute the read waveform function,there an error message came:-
'An error occurred while executing the function.
Subscript indices must either be real positive integers or logicals. '
I tried many times,but the problem is not resolved.please can you give me some suggestion regarding to solve that problem or ask the oscilloscope company to give a solution for this?
Thanking you.Eagerly waiting for your answers,
If you pass in
'channel1', 1024, 10, zeros(1,1024)
in the input field, you should see the output. I'd recommend that you use the output as
ActualPoints, InitialX, XIncrement
so you don't lose the information.
