Hi All,
I am working with an 2-port E8362C, running firmware version, A.09.42.22. Using DCOM.
SourcePowerCalibrator.CalPower is Superceded. If I query it, the PNA application crashes. Understandable, after all it is superceded.
Using the COM model, or SCPI I guess, is there another way to tell the cal power at which source correction data were generated?
Thank you,
Andy
Thank you,
Andy
Looks like SetCalInfo or SetCalnfoEx should be the place for this information. I guess the offset is what you need. Offset plus chanel power is the source power of the calibration.
