Hello
I try run data logger with USB interface on my 34450A. I found only Data:Data? NVMEM command and I can import the data. Is there any possibility to remotely start the data log function?
Is it possible to remotely configure the multimeter to perform periodic measurements, eg. every 1 second? I need to make the analysis of the slowly changing signal and for this purpose I need to perform a series of periodic measurements via a USB interface. Data logger is ideal function but I need to start using the remote interface.
Please help.
Please help.
