I'm trying to create a command expert code to save balanced 4 port measurements in a s4p file. I have been able to save single-ended measurements using the CALCulate:DATA:SNP:PORTs:SAVE command, but I can't find the option to save balanced measurements.
I believe the command should be somewhere in CALCulate:FSIMulator: but have had no luck finding it.
I am using the SCPI command set for the N5224A PNA.
Some guidance would be much appreciated. Thank you.
Just to give a little bit more information. The PNA is currently setup with 4 windows open on channel 1. In each window are 4 traces for Sxx or Sxy measurements, making up the total of all 16 balanced measurements across the 4 windows.
Edited by: Belden on Sep 18, 2014 12:42 PM
Edited by: Belden on Sep 18, 2014 12:43 PM
