4395A instead of N5230
Question asked by Kiko on Nov 10, 2014
Latest reply on Nov 17, 2014 by dhamilton
Hi
We had a N5230 network analyzer that unfortunately heavily damaged.
Usually we use the NA to measure 30 samples per second when each sample contains at least 10 different frequencies (Using remote PC).
The N5230 have much wide range then we used (We focused on frequencies less then 500 MHz)
Now we are thinking to buy secondhand 4395A.
Is it a possible to get the same requirements with the 4395A?
If not, can you recommend about suitable model. (Our budget is about 9500$)
Thanks a lot!
Kiko
