I'm using Signal Studio N7623B (Ver 6.4.0.0) in DVB-S format with an E8267D with N7623B-VFP (firmware C.06.22)
The download process completes but then a timeout error occurs. The dialog shows "SOURce:ARB:STATe?"
I assume that is indicating what code caused the timeout. Since the E8267D does not support that statement (it should be "RADio:ARB:STATe?", is there a way to fix this?
Thanks
Thanks
