Good morning!
My 15 day old oscilloscope suddenly died on me and I note that it either does the blinking lights issues or it just doesn't power up, only the fan is on. I have done some search on similar issues on the net but all I can find is this one but it is a DSOX3024A:
DSOX3024 Blinking Lights
Is it still true that the weak spot of this unit is still the power supply? Hasn't Keysight identified this as an issue?
With best regards,
Josh
Please call your local Keysight contact center. We'll be happy to take care of it.
In the top right of the web browser... select your country/location, then look for (also top right), look for "Contact an expert."
