Can we use BenchVue control Agilent power supply (E3640)?
Is it from .state file?
Where I can find .state file format?
Br.
Richard Li
Br.
Richard Li
Yes, BenchVue currently supports the E363xA, E364xA, and N670xA/B supplies. You should not need to use a .state file. Just make sure the instrument can be seen by Keysight Connection Expert (IO Libraries), version 16.3. You will have to add either the RS-232 or GPIB port information to the Connection Expert so that BenchVue can see it. If you have trouble doing this, please contact me at bv_support@keysight.com.
Brian
