This a very basic question.
Done a two port calibartion on 8753E. All of the four S paramerts are displayed. Here power to port1 and port2 will be switched on and off alterante. Suppose I display only S21. In this case for mesurement, power only on port1 is sufficient, right. In this case also will the power alternate between port1 and port2...
Thanks
Leyo Joseph
Thanks
Leyo Joseph
You are using a full 2 port calibration, and you are displaying only S21 data.
But, a full 2 port error correction requires that you measure all 4 s-parameters in order to display corrected data for any single s-parameter.
Data from all four measurements is used in the equations to correct any one parameter.
so, yes, you will be making both port1 and port2 measurements, even if you only display S21.
