Using the following code (Got from Matlab site), I am downloading a baseband signal to MXG. There 5000 sample points to define 1 cycle of sine wave.
The sample rate is not explicitly set. This waveform is played, and the output of MXG is connected to an amplifier . Amplifier output is analyzed using PXA IQ analyzer mode. I can measure the frequency of the I and Q waveforms by using markers on PXA IQ display.
If I set the sample rate in MXG as 1 MHz, I am measuring the I and Q freq as 250 Hz. How to relate the sample rate of MXG to the frequency of I and Q samples and number of samples?
% This example demonstrates generation of a custom waveform and download to
% an Agilent RF Signal Generator
% Copyright 2009 The MathWorks, Inc.
% Clear the workspace
clear all
% Define the IQ Signal from components
_*NUMSAMPLES=5000;*_
_*x_axis = 1:NUMSAMPLES;*_
_*idata=23000 * sin((2*3.14*x_axis)/NUMSAMPLES);*_
_*qdata=23000 * cos((2*3.14*x_axis)/NUMSAMPLES);*_
_*IQData = idata + j.*qdata;*_
% Define a filename for the data in the ARB
ArbFileName = 'MATLABWFM';
% Open a VISA connection or a raw TCPIP/GPIB connection to the instrument
% deviceObject = visa('agilent','TCPIP0::A-N5182A-80056.dhcp.mathworks.com::inst0::INSTR');
% deviceObject = gpib('agilent',8,19);
deviceObject = tcpip('192.168.255.228',5025);
% Set up the output buffer size to hold at least the number of bytes we are
% transferring
deviceObject.OutputBufferSize = 100000;
% Set output to Big Endian with TCPIP objects, because we do the interleaving
% and the byte ordering in code. For VISA or GPIB objecs, use littleEndian.
deviceObject.ByteOrder = 'bigEndian';
% Adjust the timeout to ensure the entire waveform is downloaded before a
% timeout occurs
deviceObject.Timeout = 10.0;
% Open connection to the instrument
fopen(deviceObject);
% Seperate out the real and imaginary data in the IQ Waveform
wave = [real(IQData);imag(IQData)];
wave = wave(:)'; % transpose the waveform
% Scale the waveform
tmp = max(abs([max(wave) min(wave)]));
if (tmp == 0)
tmp = 1;
end
% ARB binary range is 2's Compliment -32768 to + 32767
% So scale the waveform to +/- 32767 not 32768
scale = 2^15-1;
scale = scale/tmp;
wave = round(wave * scale);
modval = 2^16;
% Get it from double to unsigned int and let the driver take care of Big
% Endian to Little Endian for you Look at ESG in Workspace. It is a
% property of the VISA driver.
wave = uint16(mod(modval + wave, modval));
% Some more commands to make sure we don't damage the instrument
fprintf(deviceObject,':OUTPut:STATe OFF')
fprintf(deviceObject,':SOURce:RADio:ARB:STATe OFF')
fprintf(deviceObject,':OUTPut:MODulation:STATe OFF')
% Set the instrument source freq
fprintf(deviceObject, 'SOURce:FREQuency 1843000000');
% Set the source power
fprintf(deviceObject, 'POWer -25.1');
% Write the data to the instrument
n = size(wave);
sprintf('Starting Download of %d Points\n',n(2)/2)
binblockwrite(deviceObject,wave,'uint16',[':MEM:DATA:UNProtected "WFM1:' ArbFileName '",']);
% Write out the ASCII LF character
fprintf(deviceObject,'');
% Wait for instrument to complete download
% If you see a "Warning: A timeout occurred before the Terminator was reached."
% warning you will need to adjust the deviceObject.Timeout value until no
% warning results on execution
commandCompleted = query(deviceObject,'*OPC?');
% Some more commands to start playing back the signal on the instrument
fprintf(deviceObject,':SOURce:RADio:ARB:STATe ON')
fprintf(deviceObject,':OUTPut:MODulation:STATe ON')
fprintf(deviceObject,':OUTPut:STATe ON')
fprintf(deviceObject,[':SOURce:RADio:ARB:WAV "ARBI:' ArbFileName '"']);
% Close the connection to the instrument
fclose(deviceObject); delete(deviceObject); clear deviceObject
clear all
% transferring
% timeout occurs
if (tmp == 0)
tmp = 1;
end
scale = 2^15-1;
scale = scale/tmp;
modval = 2^16;
n = size(wave);
