I apologize if this question is asked often, it kind of seems like it would be.
I have N to sma adapters, but I have only an N cal. kit. I doubt my boss would sponsor the purchase of an sma cal. kit, so, calibrating the sma ports in that way is not an option. Can I calibrate the N ports, then then just port-extend to the ends of the sma cables? Any other ideas?
Thanks a lot,
sean
Thanks a lot,
sean
Be, in fact, if you have decent adapters, you have a good chance of getting fine results just with port extensions.
Sincerely,
tsilchia.
