I've been using an E5071C connected to a PC via the USB with IO Libraries v16 without a problem.
When I updated to the latest v17 IO Libraries software, it no longer detected the analyzer, and there didnt seem to be anyway to manually add it.
I then un-installed v17, and re-installed v16, and it worked fine again.
I've attached pictures of both v16 and v17, without touching the analyzer or USB cable at all.
Is there a known issue with the v17 IO Libraries software, or do I need some special way to set the Analyzer up on it?
I subsequently re-installed the v17 software a second time, and this time, it did detect the USB connected Analyzer.
So anyone else who experiences this problem, perhaps try un-installing, then re-installing the IO Libraries to see if this fixes it.
