For some reason "Ground" option for an "Expand About" is grayed out and hence not selectable. Resetting the instrument to "Factory Default" brings the option back but disappears once I recall my setup. I tried changing expandMode *from* 1,"center" *to* 0,"ground" - but it had no effect.
I'm running 2.38 and have the same problem on two scopes.
Thanks.
Thanks.
